Timing or Trans Problem
Hello all! I have recently put a new engine in my 1998 silverado Z71. The truck has a 4L60E with 103k miles and hasn't had any transmission problem before the engine install. My problem is: at cruising speeds I get a shudder from the trans. It shifts fine through all gear up and down and locks-up fine. I have chaged the fluid and filter and still have a shudder and there are no codes present. Is it possible that the timing is off just enough to make the TC lock and unlock causing the shudder or is the lock-up clutch in the trans. going bad. Thanks in advance. Matt
On my 96 trans am 4l60e, the TCC solenoid was bypassing fluid pressure. A new solenoid and everything works fine. I don't know if that's your problem, but you might check it before buying a new converter or having yours rebuilt. :shakehead:
