What's this called?
I just purchased an 05 Yukon.
What is the proper name for the piece of plastic which seperates the rear window and side window. You know, the black plastic piece that looks like it has vents on it. I've searched everywhere and can't find a name for it. :shakehead:
Thanks
I'm not sure about the proper name but it is a vent fixture that vents air to the outside. It's part of the fresh air system. It has a one-way flapper that only lets air out in case the pressure inside the cab gets too high. On pick-ups the valves/vents are located on the cab between the cab and the bed. Sorry I don't have the proper name. Probably some kind of 'panel'. Good luck.
As GM-Tech said,They are called the Quarter panel upper applique and the part numbers are LH-15764012 and RH-15765114.
