Hello everyone!
Silver2K4Z71
Been surfing around the boards for a while and thought I would finally post something and say hi. I live in Richmond Indiana, and my vehicle is a 2004 GMC Canyon SLE w/ 3.5l, Auto, 4x4. Lots of good information here and I look forward to joining in.
