Best place to install some guages?
Hello all,
I have a 1995 GMC K2500 with the 6.5L diesel.
The Instrument cluster is no longer registering the engine temprature so I decided to install an aftermarket guage. Now I have to tap and install a bulb somewhere but I don't know where the best place would be. "Also, the Easiest place would be nice too"
I know the engine temp is being read properly by the engine because if I unplug the stock temprature sensor from the wire the engine races.
Also the Oil presure guage does not register anything for about 30 - 45 seconds after starting the truck, but it then jumps up to where it should be. It's starting to worry me, any ideas on that? Should I get an aftermarket Oil Pressure guage? and where would I put that?
Thanks,
Mike
Why not have the factory gauges repaired?
Because of the cost. They want to replace the insturment cluster at about $250.
I knew it would be the instrument cluster because I took it out myself to replace some dead light bulbs and I forgot to disconnect the Battery cables. Never worked right since then.
Mike
Mike
Ahhhhhh. Well I have been known to skip essential steps myself
