Tire recommendation
I've seen pretty much all good reviews about Bridgestone Revos but I just don't have the budget during Christmas time to put a set of them on my HD. What are other experiences (good/bad) has anyone had with the next in line (BFG A/T T/As or Goodyear Wranglers or anything else)? Thanks!
I just put on a set of 265/75/16 10 ply E load Nitto Terra Grapplers. $692 out the door baby! I love'm. Quiet, nice road manners, great traction( except for the mud I'm told). May not last as long as Revo's but eh, who cares they look great. Goodyear? not on your life, they make the cr@@piest tires
Bridgestone Dueler A/T's..... I really like them so far, fairly agressive tread pattern but quite when riding. I got them fairly reasonable compared to Revo's.
Thanks for the info folks! I'm also looking at cranking the t-bars up a couple of turns. Is it recommended to have the front-end aligned after doing this? Also, how much will this affect the ride (very much rougher)? Thanks again!
SHOP THE FIRESTONE/BRIDSTONE STORES FOR THE REVOS. IGOT A SET OF 285-75-16 FOR 725 OUT THE DOOR. ASK FOR THE DISCOUNT AND GOOD FRIEND DEAL
It would probably be a good idea to get the truck realigned after cranking you t-bars. You will probably run into some wear issues on your tires if you don't.... I know you would hate to ruin a new set of tires :cheers: .
My vote goes for the Nitto Terra Grapplers, they also just got selected by consumer reports as the #1 All-terrain. I have a set of 295/70r17 that I run in the fair weather months. The Weld rims are too nice to get ruined by salt.
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
