brake issues
timbercutter1
[email protected]
I have a 99 4-door tahoe that I am using for a plow- hunting vehicle It has 95,000 miles. Purchased from relative this fall and now it is not driven daily. When I begin to plow (about every other day) as soon as I push the brake down at low speeds the rear brakes lock up and jerk the vehicle badly. I also have noticed that the ABS will engage even when backing up very slowly. I am guessing a bad sensor for the abs issue but why are the brakes so grabby? After driving down the road and using them a little things go back to normal.
Timbercutter1
Yep, the ABS problem is almost certainly a front wheel speed sensor. Sometimes, taking the sensor out and cleaning it's mounting surfaces is enough to fix it. There's a recall for this issue.
You'll have to take a look at the rear brakes. Perhaps contaminated with something.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
