Mods on my 05 Sierra Z71
So far this is what I've done:
Flowmaster Delta 70 Ser.
K&N Cold Air Intake
Granatelli Mass Air Flow Sensor
Granatelli 0 ohm Performance Spark Plug Wires
Diablo Sport Predator Tuner
She runs real good. Still need to adjust the idle a little. She vibrates a little when stopped at a light and in drive. The tuner will allow me to adjust that, just want to get some tech. advice from Diablo before I make the adjustment.
I think the only thing left to do is an Air Raid Throttle Body Spacer. It will give me a little more torque.
Does anyone have a similar set up?
K&N Cold Air Intake
Dont waste your money on the spacer. They arent as great as you think they are. What all have you changed with the Pred?
I just installed the performance tune that it comes with. I plan on contacting them to get a custom tune. I understand that they customize it based on the upgrades I've already installed.
Try a Crankshaft Variation Relearn to smooth the idle first. I fix that all the time. You'll have to use a professional scan/diagnostic tool to access the program.
Vernon
Where should I be idling? As I mentioned before, the truck vibrates when in drive stopped at a light ( foot on brake). It seemed to start after I put the exhaust on, which was the first item I installed.
The installers of the exhaust say the Flowmaster has nothing to do with it.
Where can I get that type of "relearn" done?
Check under the truck really well while someone holds the brakes in drive to make sure it's not your new exhaust vibrating the chassis. If it doesn't then you can take the truck to a dealer but I would find a competent independent garage who does emissions and computer type repair work like mine. Don't pay more than $50 anywhere. A Napa Autocare should be able to handle it.
Vernon
Outsource, head on over to ls1tech.com and search crank relearn.. It will take you a while to read all the info, but it will shed light on the crank relearn deal :)
TB spacers and their ilk are a joke. Just a way of fooling people who don't know the difference between a carbed engine and an fuel injected engine. Trust me, that will not give you any more torque. It will however make your intake whistle.
Some of your current mods are pretty useless too. the spark plugs and the MAF swap really didn't need to happen, and gave you no gains. The less said about the other two the better.
Get a custom tune if you're tuning anything. Mail order tunes like Wait4me and Nelson are also pretty good.
  • 3 months later...
:cheers:
Vernon
I know it's been a while, but I just got back from the dealer. They did the Crank re-learn and it didn't fix a thing. The truck stills idles low and vibrates when in drive and the foot on the brake.
To start off with, the service writer had never heard of the crank re-learn. That made me feel good :( He had to call his "super-mechanic" I guess who came out with an attitude like "who told you that would fix your problem?"
He pulled out his Tech 2 diagnostic tuner thing and did the re-learn. Nothing. I asked the service writer if there was anything that could be done to adjust the idle and he said "nope, that's the way they are".
Then I told him that I would be coming back to get the popping noise in my front end fixed, and he said there's no fix, and a recall will be coming out. I asked if he knew about the issue with the transmission getting stuck in 2nd gear while at a light and then slamming into 1st when you step on the gas, and he said "never heard of it"
I gotta tell you guys, I've just about had it with this Sierra. I'm really disappointed, not only with the vehicle and all it's problems but with the service department and not 1 but 2 different dealerships. These guys don't know crap!
Somebody tell me something!!!!! :D:chevy::chevy::fume::fume:
I would start by taking that
Granatelli Mass Air Flow Sensor off.
The factory MAF will flow more than needed. Its good for up to 8L. Probably where your problem is.
I bet that's the problem also.
Definitely try going back to the stock MAF first (disconnect your negative cable while you work). If that does not get rid of it, consider switching to the Taylor Thundervolt spark plug wires (one of my first mods on my current truck), which smoothed the idle significantly (even in a brand new '06). The Taylors are the wires everyone at Z71Tahoe-Suburban.com forum seems to have had the most luck with for smoothing the idle.
Another easy thing to try is a top-end cleaning (before your next oil change), or maybe even a can of SeaFoam in your next gas tank fill-up to clean up your fuel system a bit. I run a can of SeaFoam every 4-5 tanks (in all of our cars) to keep carbon deposits at bay.
My idle, by the way, is a little below 500 once warmed up, maybe 700 cold.
    Greg3160
    Greg3160
  • Who's Online   5 Members, 0 Anonymous, 885 Guests (See full list)
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
    • Im in the same boat. Carlink adapter comes tomorrow and dev account is in process. Would you he able to send the new instructions my way also? Question, do you have to change code and republish app everytime developer updates? Thanks for your assistance, truly the only thing i cant stand about my truck is the carplay limitation
    • Parts department or service department at the dealer.
    • I’ll take the blue one!
    • And Google AI says......... Yes, your truck can technically handle it, but you will be right at or near its maximum limit. A 2016 Chevrolet Silverado 1500 High Country with a 6.5-foot bed has a maximum payload capacity of approximately 1,770 pounds.Weight RealitiesLoad weight: Half a cord of dry hardwood weighs roughly 1,100 to 1,500 pounds depending on the wood type (like oak or hickory).Payload limit: Payload includes the weight of the wood, you, any passengers, and a full tank of gas.The math: If you weigh 200 pounds and have a full tank of gas, a 1,500-pound load of wood puts you right at that 1,770-pound ceiling.Safety TipsCheck the yellow and white sticker on your driver-side door jamb for your truck's exact payload number, as high-end luxury trims with extra features have slightly lower capacities than basic trucks.Expect the rear end to sag noticeably.Drive carefully, avoid sudden turns or stops, and keep speeds low if you have to travel a distance.
