Power steering failure
I went out last night to put the truck in the garage, I needed to turn it around and since there was plenty of snow on the ground I cranked the wheel and popped the throttle to spin it around. Went to straighten out the wheel and… no power steering. It was a spirited maneuver but nothing to aggressive, the wheel was at the lock and I heard the PS pump strain a bit.
Belt is good, fluid level good, no fluid loss and no odd noises. I tried to bleed it (jacked up, turn wheels back and forth), no luck. The pump is very quite, like its not pushing any pressure, even at full wheel lock there is no noise from the pump. Seems like the pressure bypass valve stuck open, possible? Could is be an EVO issue, fuse? Could I have damaged the steering box, blown an internal seal?
Guess that’s what I get for playin like a dumb kid. :)
Gary
'97 Suburban 1500 4WD, 5.7L
the PS pump's drive shaft may have fractured
I think he hit it right on the head w/ this one...I did the same thing once on some ice and it turned out to be the pump's drive shaft but i suppose it could be something else
Bugger, I wouldn't think it could do that, I would figure there was a pressure bypass... Guess its not idiot proof (me being the idiot). :)
NAPA says $113 for a rebuilt pump with reservoir, $46 without. Is the reservoir a pain to switch over? Or is this a part that would be better to get new/dealer?
Thanks for the replies
Gary
Bugger, I wouldn't think it could do that, I would figure there was a pressure bypass... Guess its not idiot proof (me being the idiot).  :sigh:
Gary
Easy job with the right tools. Get a pulley puller, don't use a 3 jaw puller unless you want to destroy the pulley.
