Has GM fixed well known problems
I would like to know if well known issues such as intermediate steering shaft problems, driveline clunk, piston slap, instrument cluster problems, Autotrack trasfer case problems, etc. have been resolved on the '06 trucks.
Anybody has piston slap or driveline clunk on their '06 truck?
My '06 has no clunk in the drivetrain like my '04 did, neither one had piston slap. I replaced 2 autotrac switches on the '04 in 12,000 miles. I only have 500 miles on the '06.
My '06 has the 3.42 rear end and the '04 had the 3.73's. The '06 has less go than the '04 did but seems about 2 mpg better on fuel economy.
The '06 also stops MUCH better with the rear drums instead of discs.
Mike
thanks,
I have about 1100 miles on mine. I have 3.73 gears. So far no problems and I hope it stays that way.
  • 4 weeks later...
My 05 was ok too untill it hit 3000 miles and all of sudden the tranny started to clunk. Its been back several times to get rectified but it still clunks
11000 miles on my 05 Z71. Quiet, caddylacky smooth. Strong puller. I love it. So far (!!!), best truck I have ever had.
Not a single visit to the dealer for warranty issues.
UH OH you just jynxed yourself now...you'll be on the shop here pretty soon... :D
