Whoo-hoo!
DigUout
Though You did make me think of soemthing.
I'm sure there are some bored mules in Afghanistan.........:P
Geez!!  Some of you guys really need to get girlfriends!!  :D
I fall into that club. LOL But I don't spend alot of time thinking about mules.
