OK I need help
Suburban Guy
I just finished installing a new motoro and tranny in this Suburban and when I connected the battery cables it energized the fuel pump and several of the instrument lights w/o the key in the ignition.
Any idea what causing this? Is this the antitheft thing?
SG
I don't remember '95 having theft deterrant. In any case, even if it did, it wouldn't cause what you're seeing. No idea what may be hooked up incorrectly or shorted together.
