My 2000 SS Z-71
Here is some pics of my 2000 Chevrolet Z-71 with 138K on it. I bought it back on Nov. 5th 2005 and it sat stock other then the dual exhaust. I put the 285-75 R16's on it with the chrome 10" wheels. Fender flares painted, door handles are in the shop getting painted. Billet grill, billet A/C knobs, billet head light switch, billet radio knobs, billet door locks, billet trim around the passenger A/C vents. XM radio, Esclade instrument cluster, white bow tie on grill, SS emblems on both doors and tailgate with a GM performance division emblem on tailgate also. Clear head light lens and clear parking light lens with Xenon blue head lights. Also done the mod where when I turn on the brights all four lights come on. Hypertech power programmer III, K&N cold air induction and headers.
You can't if they're hosted on Yahoo!, because they don't allow hotlinking.
Imageshack, photobucket, and a few others allow it, within reason of course.
Nice truck BTW. :cheers:
