MaroonZ71 Posted February 7, 2006 Posted February 7, 2006 Hello everyone, I am new to this forum and it looks like this is the place to go for questions about my Chevy truck. I have a 2000 Silverado Z-71 that is spitting fluid out of the vent hose on the front axle. I first checked the fluid level, it was low so I topped it off and drove it around. The problem continued. I was told to drain the fluid and replace it. I did that and the problem continued. Now I'm open for more suggestions. Any thoughts would be greatly appreciated. Thanks Brett
MaroonZ71 Posted February 12, 2006 Author Posted February 12, 2006 In case anyone runs into this problem, this is what I did to fix it. The vent tube attaches to a nipple that can be removed from the differential. Remove this piece, it is about 2.5 inches in diameter. (I think I used a 15/16 inch socket to remove it, it almost unscrewed by hand) There is a rotating valve on the inside that must have gotten stuck in the open position allowing fluid to leak. I cleaned the part and made sure everything was free and reinstalled. I have not had a problem since. This fix was recommended to me by a heavy line technician at a local Chevy dealer. He said he has seen this problem on occasion. I hope this helps anyone in the future. Brett
Norseman Posted February 14, 2006 Posted February 14, 2006 Hello everyone, I am new to this forum and it looks like this is the place to go for questions about my Chevy truck. I have a 2000 Silverado Z-71 that is spitting fluid out of the vent hose on the front axle. I first checked the fluid level, it was low so I topped it off and drove it around. The problem continued. I was told to drain the fluid and replace it. I did that and the problem continued. Now I'm open for more suggestions. Any thoughts would be greatly appreciated. Thanks Brett <{POST_SNAPBACK}> Thanks Brett
