Steering Clunk still there...
Well I brought my truck in last weak about the steering clunk.... and although it seems better it is still there. They only greased the steering shaft. Well I got to looking/poking around and I noticed that if you look under the dash the steering shaft has a large plastic/Teflon ring. I can literally grab onto the shaft on wiggle it around and it appears to me that the noise I hear is coming from this plastic/Teflon ring having too much play. Can some of you guys check out your truck to see if they have this play. The shaft seems to wiggle at least 1/8 of an inch in all directions.
I can get some photos if it will help identify the area I am talking about.
i replaced the gray colored plasitc bearing on the shaft located on the collumn under the dash. Had a clunking noise at very low speeds on my nbs 2500. I think the part was dealer only and was between 15 and 25 dollars. Of course this was 4 years ago. The clunk went away, didnt take but maybe 1 hour to do, you have to drop the collunm down and slide it part way out, later the shaft that goes through the fire wall went bad so i changed that.
i installed the BORGESON shaft last night. SWEEEEEEEEEEEEEET. took about 1 hour. what a noticeable difference. tight and more responsive..
If you don't mind me asking, where did you get it and how much did it set you back cost-wise? My truck is slowly getting worse and I don't want to have to waste time making multiple trips to the dealership :cheers: .
  • 1 month later...
please tell me more about how to replace the "gray plastic bearing".
thx - mc
    Camyon
    Camyon
  • Who's Online   4 Members, 1 Anonymous, 1,256 Guests (See full list)
