running boards
I have a 2000 Tahoe and was plannig on purchasing some running boards for it. I haven't decided if I should hit the dealer, ebay, or some other aftermarket business. What I would really like to know is what years are covered by the running boards that would fit my truck. I.E. will they fit all 00-04 Tahoes or are they specific to each year?
I have the factory ones on my 2005 denali xl and I was in north carolina and was pulling up the drivway at the house on sugar mountain that we had rented for the week of the new year this year and I got half way up a u shaped driveway and 3/4 of the way up I hit Ice and slid down the drive and ended rear in a ditch and if it wasn't for the stock running boards the whole under side of my truck would have been trashed the dealer said ( I also used to paint cars for a living I looked at it when it was on the rack) hope this helps.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
