Flowmaster 40's or Glasspacks
on my 2000 4.3L vortec silverado ive been wanting to upgrade the exhaust to get a much louder and deeper tone should i go with the flowmaster 40's single inlet and dual outlet or just one glasspack comming straight from the y pipe that leads to the cat converters? with the flowmasters id do a dual exit comming straight out the rear of the truck. with the glasspacks id probably just run it with the stock pipes and exit. ive heard that glasspacks also wear out much faster than normal flowmasters is that true?
Flowmasters sound great. Those and Magnaflow sound the best IMO. I'm not sure about a V6 though.
Anything over Glasspacks for that matter :cheers:
