Help Heater Problems!!!
Hello
I am having a problem with my heater. It will only blow when the fan is turned to 5 on the 1,2,3,4 does nothing. Truck is an 02 silverado Ext Cab. Any help would be VERY much appreciated..
Fuse maybe??
I really have no idea.
Hello
Fuse maybe??
Speed is regulated by a resistor usually in air duct for cooling it. When resistor is burnt out only high (wow speed) works. I do not know precisely where the resistor is but it is cheap and easy. You'll be OK.
Ken
Cool.. If someone could point in the direction of the resistor, that would be awesome.  Thanks
To our brother countryman in Canada,
I googled and the concept and the word is it is passenger side under dash in the outlet of the blower. A block with a multi wire plug. They say it is 15.00 or so. two screws.
Ken
ps I was in Canada last year and met a lady that thinks we don't like Canadians. Please tell everyone up there we love all of you!!
i just changed mine! its on the passenger side, the unit has a rectangluar base, and two screw. EASY to locate.
Rupes
Do you know the part number.. I have called two dealers and gotten two different part numbers. 89018596 and 89018957
Thanks again1
This same problem happened to me this morning. I only get heat on 4 or 5.
I'll have to figure out where this resistor sits so I can swap it out.
sledr
Changed the blower motor resistor yesterday... $31.00 Candian, taxes in.. 10 minute job.. Thanks to those who provided advice....
I wonder what this would have cost had I paid someone to do it!!!
300.00 american. All repairs of a trivial nature cost 300.00 american at the stealer.
ken
  • 4 weeks later...
Is this the same fix for if you have air blowing out of the vents when the fan is in the off position?
I believe when the Fan is in the off position it puts the vents on fresh air and just let's air in as your going down the road.
I have a question about regulating heat. My temperature setting has like 1/3 for cool/warm and the rest 2/3 of it is really stinking hot. Anybody have any suggestions????
Cheers
Evan
  • 2 months later...
For my 2002 Tahoe, the part number was 89018597. The dealer verified. It said was for 99-02 C and K 1/2 and 3/4 ton trucks.
EDIT: I found more info on the Pace Auto Parts website. It looks like p/n 97 is for 2002 and prior vehicles, and the 96 block is for 2003 and newer. Check to be sure.
    appletrav
    appletrav
  • Who's Online   0 Members, 0 Anonymous, 284 Guests (See full list)
