2005 Avalanche electrical problem
SIERRA2000
I have a 2005 Avalanche 2WD WBH 1500 5.3L.
When driving at night or dark enough for the Auto headlights to come on, with all the major accessories on, heater, radio, etc.. and at speeds greater that 35 mph all the lights on the vehicle will flicker even the headlights. The voltage meter will fluctuate from just below the line to just above the line. This drives me crazy. I have had it to the dealer a couple of times but of course I get the famous 'Can't seem to duplicate the problem". Can you help me?
Normal condition I'd say.
Volt Gauge Fluctuation - keywords cluster electrical excessive fluctuation gage generator intermittent IPC operation volt voltage voltmeter wire #PIT3331A - (Dec 16, 2005)
2005-2006 Cadillac Escalade Models
2005-2006 Chevrolet Avalanche, Silverado, Suburban, Tahoe
2005-2006 GMC Sierra, Yukon Models
with RVC
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
Some customers may comment that their voltmeter is fluctuating between 12 and 14 volts on their full size pickup / utility vehicle.
Recommendation/Instructions:
Starting with the 2005 model year, light duty full size pickups and utilities, are equipped with a new Regulated Voltage Control (RVC) system. This system turns off the alternator when it is not required in order to improve fuel economy. The alternator will turn back on when additional voltage is required. This will cause the voltmeter to fluctuate between 12 and 14 volts as opposed to non-regulated systems which usually maintain a more consistent reading of 14 volts. This fluctuation with the RVC system is normal system operation and NO repairs should be attempted.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© Copyright General Motors Corporation. All Rights Reserved.
with RVC
Condition/Concern:
So, how would I go about geting rid of this "RVC" annoyance????? It drives me crazy. Every other GM truck that I have owned (5) went to just above 14 and stayed there unless there was a problem. I would just like to know I have full electrical power when the truck running. If I was that worried about such minute amount of gas, I would probably drive something a little easier on gas. Let me know, Please and Thank you
Trade your truck in on an older model. Otherwise, don't let it get to you. It works.
I have an '06 Silverado and all I see is voltage fluctuation on the meter between 12 Volts and 15 Volts. There is no flickering of lights or any other malfunction. What Sierra2000 is describing does not sound normal to me. If his voltage gauge needle sweeps from one end of the scale to the other end, something is definitely wrong. Could it be he has an intermittent problem in the voltage regulator or some other system component?
    overspeed
    overspeed
  • Who's Online   3 Members, 0 Anonymous, 228 Guests (See full list)
