WHEEL SENSORS WITH 22'S
I Just put 22in wheels on my 05 denali and the I paid and got the wheel sensors for the new 22s instead of pulling them from old tires and at first for like 25 miles they were fine now I get a service tire sensor across the dash, I push one of the steering wheel control buttons and it goes away till I start the car again. If I get the wheels progaramed for the 20s instead of the 17s that were on it would this eliminate this problem? Thanks
Did you program the new sensors? I would imagine the receiver wouldn't know anything about the new sensors you put in (vs. the old ones you kept on your other set of wheels)...
I don't think wheel size in itself has anything to do with whether or not the system can see the sensors--if that were the case, then the sensors I took out of the factory 17" wheels and stuck on my 22" wheels wouldn't work, no matter how much reprogramming /relearning of the sensors I did.
You still need to program them; the only time you probably wouldn't need to reprogram them is if you took out the old sensors, put them in the new wheels, and then put those wheels/sensors in the same location that the sensors originally were at--e.g., take out old LF sensor, put it in new wheel, then put wheel in LF location...repeat w/ RF, RR, LR sensors.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
