Stock Exhaust Size
2002 5.3 z71.
I want to order a 40 series magnaflow from summit and I don't know what size inlet and outlet I need.
I'm going to cut the OE muffler out and section a piece of pipe. Will also use stock tailpipe.
Anybody know off the top of their heads what the dimensions are?
2002 5.3 z71.
My stock size is 2.75". I just got a 2.5" muffler from summit and stretched it out to 2.75". Works like a charm. :thumbs:
