Magnaflow cat back rusting ?
I installed my Magnaflow cat back system part #15778 sometime last summer and today I notice the tailpipe is rusting. Now I thought all there components were stainless steel.The muffler looks almost the same as when I installed it but the inside and outside of the tailpipe are pretty rusty and not surface rust, I'm talking about flaking kinda rust.The clamps also look like there is some kinda plating peeling off.
I'm wondering what grade of stainless steel there using,if it's 316 or 304. Anybody have any thoughts on this before I contact Magnaflow.
My magnaflow #15818 catback appears the same, just without the flaking. I believe it's stainless, just a lower quality so there is still a small amount of corrosion.
Jeff
    • Correct.  2019-2020 are serviced by a different p/n.  19420611.   The recall engines 2021-2024 are serviced with 12740076.     What the difference is between the two, I'm not sure, but 2019-2020 only show 19420611 as the replacement engine p/n.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
