Dash emits a repeated tic-toc sound
oquevix
Alright now. Yet another problem with this 2003 Yukon, 5.3L Z71, 55,000miles. A tic-toc sound - very methodical like a loud clock comes from the driver's side dashboard. It comes on after a few miles of driving ans stays on until the engine is turned off. It even stays on when the vehicle is at a stop light. Kinda like my own little drummer along for the ride.
Any ideas on what it is, what causes it and what the fix is.
Thanks,
Axe
It's one of the A/C door actuators. While it's making the noise, try moving the temp lever (or knob) to a different position and see if it momentarily stops as the temp is changed. Or, it may go away for a while.
If that does nothing, try chaning the mode (upper vents, lower, bi-level, etc.) to see if that affects it.
We mostly see the left temp actuator and/or the mode actuator cause this problem. Hopefully, it's no the right temp actuator as that requires several hours labor to replace.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
