Dorr hinge pins & bushings
30-A rider
My 93 burbs driver door hinge pins and bushingare are way due for replacement. To get what I hoped is a premium pin I bought the pins and bushings from a Chev dealer. I have done hinge pins on my chevelles and my previous 84 burb but this one is different. I think I may need a spring compressor tool to do this for the door spring.
So my question is do I need to rent/nut this tool? Anyone ever done hinge pins on a model year like this and if so, any insight, recomendations, tricks or instructions they can offer?
Thanks,
Scott
Thanks,
Scott
I would get the tool for that spring as it makes it very easy to replace it while being a heck of alot safer. Search the tool places on the net for gm door spring tool.
I agree with Mr. Smith 100%. You have to have the spring tool. I use very large channel lock pilers to press the bushings in. Then use a socket with the pilers to seat the bushings fully.
Question to Mr. Smith, Chevy Tech007 or anyone else who has done this type of hinge?
All other hinge pins I have done have been on Chevelles or Gm truck from the 80s..typically they were done by taking the entire door off. When doing my 93 pins any advice....do you leave the door on to do it or take it off completely?
I bought my spring compressor tool for about $12 from a body supply shop. Money well spent. I was able to do one without the tool, but it took all day. With the tool it's about an hour job and a beer for your buddy steadying the door.
I used my engine hoist with 2 cargo straps to hold the door up. Alor steadier but if you only have a floor jack then have someone steady the door while you work.
I used a tow-strap and a hook in the ceiling. :chevy:
    • Most say the oil temperature needs to above the boiling point of water to rid it of moisture and long enough to dry it. Many think that is about a hour at 212 F or more. Those people have never line dried cloths in a Midwest winter. Leave a pan of water sitting on the counter and eventually it all evaporates. So heat drives the time it takes. Water in oil under 175 F, the Nitration initiation temperature, is a minimum then for temperature and samples I've done that use Karl Fisher method say about a hour (in a healthy well tuned motor) over 175 F will dry it to under 800 ppm. Low enough to not be much of a factor. Motors with weak rings will take longer and the colder the air temperature the longer it takes.   On a cold motor there is also the condensation temperature. Blowby gases that contain moisture are subject to that cold cylinder wall, like sweat on a glass of ice tea. But also subject to the Law of Partial Pressures. Wear studies by GM and the DOD  indicate wear is a real issue below 85 F and a concern to 140 F but doesn't become a minimal factor until about 160 F. You know this intuitively when you see water vapor exit the exhaust pipe until the system gets above the dew point. It isn't magic, it's physics and it fascinates me. I know you didn't ask but....I over share sometimes. 😉    You keep the Camaro's high and tight.
    • Move further away.   Benefit of living out - none of our cars get short cycled, plenty of warm up time.   Curious how much time/temperature it takes to drive moisture/condensation out of the engine?
    • Switch a a 100% synthetic trans fluid, Amsoil works for me.
    • First of all sorry, I know there are a ton of transmission temperature threads...   My truck is a 2025 LZ0 High (10l89 10-speed) High Country with NHT max trailering package. The NHT package is supposed to have "enhanced cooling."   Normally the trans temp sits around 200. It seems like with any real stress it quickly jumps into the 220s (for example climbing a grade unloaded at lower speeds). I haven't towed much with this truck, but I'm concerned if it gets this hot unloaded.    I've tried a few different things to keep the temps down (tow/haul mode, sport mode, low range when that makes sense) and nothing seems to affect it.    I'm curious if others are the same behavior or if anyone has found techniques to keep the temps down. It seems like it just can't handle reduced airflow at lower speeds, even with relatively light loading.    Thanks!
    • I'm at 105,000 miles on my baby Duramax. No issues yet. I hit 31 mpg's traveling through hilly terrain to a project in Colorado. I will buy another 3.0. I'm not concerned.
