interior lights time delay problem
bobstocker
1998 GMC Sierra K1500 truck
Interior lights have problem with shutoff delay. Sometimes interior dome light will turn off after door closes , other times light stays on indefinetely. I must use dome overide switch to get light to turn off. Both door switches appear okay.
Is there some delay switch timer module or something that is faulty that can be replaced? I hate finding the light on and battery run down because light has not turned off. Pressing dome overide switch gets rid of the lights staying on problem but also never have interior lights come on when you open door. Pressing this switch also keeps the exterior cargo lamp disabled. When you press keyring door lock button, the dome light comes on briefly and shuts off after entering vehicle and starting engine- so this part works correctly. but would be nice to not have to keep overide button in all the time and have inside lights come on and turn off as supposed to. Has anyone else had this problem and/or have suggestions for what to look for and fix this - thanks
I dont have the luxury of the power locks or keyless entry on my 98, but I have had the same problem. The problem i ran across was just the door switch was faulty. Replaced it and it is fine now...it does beat hitting that dome override. :chevy:
Thanks for the suggestion , I would assume the logical choice to change wold be the driver side. Did you find compatible switch at car parts or was it necessary to use GMC dealer?
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
