Loose Door?
Hey guys,
This has been happening for about 3 weeks now and i cannot figure it out...everytime i hit a pot hole or some bump in the road that my front drivers side tire hits my front drivers side door sounds like it is a little loose....like not a rattle but a "loosness" this might make no sence...OK...this might make it better.,...it is similar but not as major as if you shut your door half baked so it is not open open but it is not closed correctly and you can hear the wind and stuff....it is like that but not as bad. Any suggestions...
Is it possible your back door is not fully latched? It needs to latch fully at the top *and* the bottom. Push on it and see if it moves, at the top, and at the bottom, separately.
mmmike..i will check that...but i am pretty sure that i am getting it shut all the way....its one of those things that is just barley annoying enough to want to address it and yet not annoying enough to spend a weekend on...
