stock bf goodrich tires...
the stock bf goodrichs on my truck have about 14k on them. but i was noticing the other day that it looks like theyre shredding or something. the white lettering is becoming kind of flakey and the tire walls themselves look like someone has been cutting on them...not through to the tire but it sort of looks like its shredding. anyone have a similar problem with these? should i take it back to the dealer since its still under factory warranty or would they tell me to go to hell? thanks.
Have you used a power washer to wash your truck? If you have, you could have cut the sidewalls with it. I had i happen to me once when I was rinsing the mud off my tires with a pressure washer. If not then hell yeah take that back to the stealer
youre right they are bridgestones...my bad.
ive used a power washer...but i havent had it sit there on the wheel. just a brush by after i spray the wheel cleaner on. nothing too hardcore.
I would take them back then....may be a defective set of tires, and remeber the whole Firestone thing a while back....Bridgestone is the same company, better safe than sorry
i've been told by the dealer that gm is aware of the problem and told the dealers to do nothing until they figure out what to do...mine are actually losing chunks of rubber and my dealer has told me that he's going to see what he can do
i've got 23k on the truck now and i've rotated them every 3-5k by the dealer
yeah i noticed a chunk missing from my right drivers side tire today. anyone else know of any factory defects on the 05 model? im glad im not the only one with the defect.
edit: ill post up some pics tonight if i can remember.
  • 1 month later...
SOunds like a issue with tires maybe but you need to go to a Firestone dealer, not car dealer because tires are covered by tire manufacturer too. Also side wall problem can be caused by to low of TP for load and speeds.
WTF? No he doesn't.
He needs to take it to the freaking Chevrolet dealership, they'll deal with Firestone/Bridgestone if need be.
That white stuff? In the pipe? Don't smoke it. It's crack. It screws up your judgement.
WTF? No he doesn't.
If you read the fine print in your warranty you will find that they are warranted by tire OEM too. (otherwise Ford would not have been able to slickly pass the blame to Firestone) Also the whole Firestone thing was a sham in that it was really Fords fault for recommanding too low a tire pressure for the load of the vehicle and the lower the pressure, the more the tires flex and the more heat that is generated in the sidewalls. Tire pressure is critical for good tire and sidewall life though some would like to think otherwise though and are quick to blame the tire. Yes the tire may be at fault here too but lots of other factors too.
Yeah...The armies of lawyers, experts, and engineers just missed that "sham", and you caught it. Whatever man.
I never said that the tires weren't under warranty from the manufacturer. I said that he needs to take it to the Chevrolet dealership. That's because that's what he should do. Let's say he follows your advice, and takes it to a Firestone shop, and it's an issue with the shocks. You think they're going to bill GM for the shop time, shock replacement, and new tires? No...If the man follows your advice, he's going to be out some pretty big $$$ for a diagnostic and some parts that a Chevrolet dealership wouldn't have charged him one cent for.
Do you WANT the man to lose money? Seriously, I can't follow your logic here. What possible benefit could there be in NOT taking it to the Chevrolet dealership?
    • That's interesting, I assume that would add to the cost of the oil but also I was forgetting to bring up the issue of the low tension rings allowing more oil past which in turn forces the cats to have more oil additives pass through them that wouldn't otherwise so they are creating that problem and of course its all in the name of fuel economy. Mind you the other issue would be the lack of additives that fight the formation of carbon within the piston ring grooves which turn the engine into an oil burner and with in this GM forums case is your average off the shelf Dexos licensed oil, meanwhile the other off the shelf oil being Valvoline's R&P isn't licensed and the only one that is which is that certain Mobil oil that came out recently ( its not even being marketed in Canada ) and only a fraction of vehicle owners are going to be using it out of all the other oils on the shelf or the quickie lube bay that meet the Dexos spec by way of actual licensing.    Also I suspect that its an easy excuse to pool the non turbo DI engines in with the turbo DI engines and design the oil to not have LSPI issues in the most demanding engines and short change the naturally aspirated DI by not offering a higher concentration of additive package they could handle and still not be at risk of LSPI.    I wonder if Amsoil flipped the switch just lately and did whatever packaging designation at the same time as I wonder what oil formulation I would have bought in May, of course I don't know when it was packaged at the factory vs how long it was in storage at the Edmonton warehouse. I know its been said at least in the past that the big players switch over to a reformulated oil but the packaging has not changed until they make that move as well so there is that cross over time where its a new formulation in a predated formula marked package.
    • Hmm. A real reason to not just use the odometer to determine OCI?
    • Sad thing is that this doesn't have to be the case. LSPI can be solved without a reduction in TBN. Swap Ca for Mg.  Cats are not a issue if the OEM can get a ring and valve guide seal even at SN levels of SAPS. Dizzy is purring like a kitten with a bowl of warm milk. 200K of Full SAPS oil and zero detonation issues and nice a clean inside and out. This shouldn't be an issue. It isn't 1920.    Tell ya what AMSOIL SS is excellent at, internal cleanliness. The new formula is even a step up from their already outstanding cleanliness levels. Can't say the OEM offering is quite that clean. There marketing suggest the SS is cleaner.     That is the only defense with at shelf oil. Nothing wrong with them if you ignore the marketing and OEM 'recommended' OCI and use a thimble full of common sense. 😉 You go sir.
    • I started with a folding cover by BAK PAC on my 2500. It went bad after close to 5 years. Bent and vinyl coming loose. Contacted BAK and they gave me a very good discount on a Revolver. Had it a number of years. Mostly outdoor storage. Some garage storage. Vinyl started to come loose. Still under warranty so they replaced to cover. Sold the 2500, bought the 1500 and got another revolver for it. Had it a couple years now and no issues. I store it indoors. Got a bit of discount when buying it as well. If you are seeing problems, contact BAK or real truck and let them know. Customer service was pretty good. But I think they changed their warranty.
    • I agree, there is no one answer fits all as every rig is different, one may be pulling some little aluminum fishing boat while another is towing a monstrosity that weighs a lot and hopefully the owner if the rig has some prior experience to know what drive mode they should choose.    It also struck me and this is from watching a few of those boat ramp escapades videos in the past, Ford being one of the vehicles that has the auto front axle hubs and sure enough its found out that one hub has crapped out and won't engage and may not have manual hubs to even select on both sides so they are on the boat ramp stuck with no four wheel drive and spinning .... they flat out need a tow to get up the ramp and deal with the vehicles new found issues. That can happen to all brands of pickup, finding out either four wheel drive or 4 low isn't working right at the time its needed it to work as some electronic crap has failed.
