Any experience with ebay fuel pump
Does anyone have any experience with fuel pump bought on eBay, with $130 price tag? Seem pretty cheap.
Some reviews say that it is not Delco fuel pump. But, when I asked the guy who sells them, he said that we buy our pumps from OE manufacture. He didn't state if it was Delco. Also he packages them in regular cardboard box, without Delco logo, but he said that he buys them in bulk, that is why they don't have Delco OE boxes.
What are your thought on this? Any experience with eBay pumps.
Thank you,
Dimedrol
It's like tires, buy it locally and save alot of possible hassle. Mine was $220 from the local auto parts store.
2000 5.3l GMC Sierra.
I purchased one a year ago off ebay, and it is still working fine, the only problem I'm having is the gauge has started to show empty again and then sometimes it reads correct.
That doesn't sound like it is working fine? :mad:
Sounds like you got one of the pre-2001 fuel pumps?
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
