Dead Fuel pump?
notmo
I just went to the store to get dinner, truck started fine and then stopped and filled up on gas. Won't start. poured a little gas in the intake and it started for a couple seconds.
Checked fuses, good
checked loose wires, none
blew through fuel filter, good
tried to turn over motor and would expect fuel to shoot out from the filter when I hooked it back up to the pump side line.
checked relay on test bench and it works but couldn't hear it click on when I turn on the key.
checked pump fuse
Should it flow strongly like a strong stream, light stream or trickle out?
1994 4.3L V6 gas engine.
2 wheel drive.
New fuel filter as of 4 months ago
