Truck not going anywhere, need help
I got a tune for my 2001 chevy pickup from wait4me about 8 months ago. My wife is driving it, and she has had a couple of problems with and I was wondering if you all have had anything happen to any of your trucks like this. The problem is that whenever she is stopped at a stoplight and she hits the gas, the engine makes a noise and it doesnt go anywhere. She says she puts it in park and then drive again and then it takes off. This has happenend only three times in the last six months. Was wondering if you guys have any insight on this. Should I maybe put the stock tune back in and see if it does it again. Thanks for your help.
Sounds to me like your transmission might be slipping. If your at a dead stop and you press the gas for a second and the vehicle doesn't go anywhere, it might be your transmission slipping out of gear then engaging.
Mine has done something similar but only a few time a year. I come to a stop. Hit gas, truck won't go, hit gas harder, starts to move, then downshifts into first with a slight bang. I have learned to let off the gas before it slams into first. It has happened when my truck was stock, after the trans was rebuilt, and after the wait4me tune so I don't think it is related to the tune. I've never gotten a good explanation and the dealer "could not duplicate" so I ignore it. 167K now with no issues.
It has only happened three times. But it has happened twice in the past two weeks. My wife thinks it has to do something when the pavement is wet. I have no idea. If anything
I will start driving it again.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
