Program 97 Burb Keyless Remote
I've looked and looked and all I can find are these instructions for programming a 2001 suburban:
1. Close all the vehicle doors.
2. Insert the ignition key into the ignition lock cylinder.
3. Press and hold the door unlock switch.
4. While holding the door lock switch in the unlock position, cycle the ignition ON, OFF, ON, OFF.
5. Release the door unlock switch. The doors will lock and unlock to confirm the program mode.
6. Press and hold the LOCK button and the UNLOCK button simultaneously on one transmitter. After a delay of approximately 15 seconds, the doors will lock and unlock to confirm the programming of that transmitter.
7. Repeat the previous step to program up to 4 transmitters.
8. Turn the ignition switch to the RUN position in order to exit the keyless entry transmitter programming mode.
9. Operate the transmitter functions in order to verify correct system operation.
These directions don't work for me. I have a 1997 and I know its equiped w/ keyless entry, but can't figure out how to program it. The dealer said they could program it for me for around $50. Can anyone help?
  • 1 year later...
I know this was from near 2 years ago, but I just used this link to program my remotes, and I was happy that it was here. THANKS
