Hello Everyone
Hey guys,
Been driving chevys forever.
Just picked up my 06 sierra SLT ECSB 1500 5.3 HO last night.
Very curious about mods to add power.
The more I read about the different tunes the more :cheers: I get.
Anyhow, intake, long headers, and a tune are pretty much a given.
I just need to choose which to use.
the higher ratio rockers sound interesting too.
:D:crackup::(
    Brendan C
    Brendan C
  • Who's Online   4 Members, 1 Anonymous, 1,194 Guests (See full list)
