i am thinking about getting the 20 inch chrome silverado ss wheels and tires for my 06 silverado 1500 2wd...what size of tire should i run on them and will it be a problem because my truck has drum brakes on the rear?
I would just stick with the standard "SS" tire size,P275/55R20.
I do recommend getting the PCM reprogrammed for the tire size change.
And you'll have no problems with the drum brakes.
i am running the ss wheels but have 275 60 tires. it is 4wd and the tires barely clear. since you have a 2wd i would stick with the 275 55 max
I just put a set on my 06 lowered 4x4 and love them. Stock tire size. Same hieght as 17 inch tires I had so pcm reprogram not needed. I don't no why you would have to reprogram for width?
does anyone know or bought any wheels from www.lwnt.com they offer replica and oem gm ss wheels and tires for 1595.....how can they sale the oem gm wheels and tires for so much less than other dealers?is their oem gm wheel a replica or is it original gm wheels?
