Air leak around Door??
I have an air leak in my drivers side door where the rear access door meets.  My local dealer said they adjusted the striker on my passenger side to fix the same problem but they didnt fix the drivers side. Does anyone now how to adjust the striker or where its even at??
Thanks!!
Here's some info on one of my pages.  http://tommy3z71.homestead.com/hayne_manual_stuff.html
It just involves loosening the screws/bolts and moving it a little to make adjustments.  You may want to mark the area by tracing around the area with a crayon or something so you know where you started from in case you want to move it back.
Good luck.  :devil:
Good luck.  :devil:
If adjusting the latch/catch doesn't solve it, the problem may be the window in the rear door.  There's a TSB on it and the dealers all know about it.  They'll replace the whole window unit to fix it.  I had one of mine done.
  • 5 years later...
Thanks!!
MountaineerTom (or someone, please), can you post the information on here? I am having the same problem and want to see what the "correct" procedure is before I go messing with it. Thanks from Bridgeport, WV.
