blown ecm bat feed fuse
snoozer
I have a 1989 Chevy Suburban 5.7 1/2 ton and recently I keep having a problem with the ecm bat feed fuse blowing. This problem started about 50 miles after having the heater core replaced, so I don't if something got messed up during the replacement or what.
If I replace the fuse truck will start and run about a dozen times then the fuse blows again.
The last time I replaced the fuse it blew out again within 2 blocks, but luckliy I was close enough to home to coast into driveway. Next day I replaced the fuse and trcuk was hard to start, ended up holding the gas pedal half way down while cranking the starter, then it started, but idled very, very slow, so shut it off restarted and it was running to fat at idle, once again shut off restarted and it ran fine, nice smooth idle.
I have not drove the truck since having the restarting problem. To afraid of getting stranded with it.
Talked to repair shop who installed the heater core and they seem to be convinced the fule pump is pulling to many amps and causing the fuse to blow.
Not sure how they came up with this, but I thought I would get some ideas from here before going through this expense.
btw I did replace the fuel pump relay shortly after this problem started, but it did not help.
Any suggestions on what to look for
Thanks for any help
Mark
  • 4 weeks later...
replaced fuel pump and 114 miles later fuse blew again. engine just shut off, replaced fuse and it started right back up, but engine was idling very slow.
Any suggestions on where to look for the problem
Thanks in advance
mark
my truck was doing that same thing and i found it to be a wire in the harness behind the engine by the distributor had worn through and was shorting out intermittantly. that truck was a 1997 k3500 with a 454, but your symtoms sound the same.
Was it blowing the ecm bat fuse?
i will have to double check what the fuse was labled for, but yes it was blowing the fuse and wouldnt start until i replaced it.
If you get a chance could you please check for me.
Boy don't you just hate electrical problems?
Snoozer it is exactly what 454ss said it is. I had the problem in a 90 V3500 (same body style as your sub). When they replaced the heater core they were probably working in the area around the rear of the motor, passenger side and thats where the short probably is. They didnt cause it, they just brought it to your attention sooner.
Do the "wiggle" test in your driveway. Start the Sub up and start wiggling wires towards the back of the engine compartment, closer to the distributor and the back of the passenger side cylinder head. You'll find your short pretty quick.
Problem Solved!! Thank you c502cid and 454ss you were right on the money.
Oil soaked, bare wires right were you said to look.
Thank you
Thank You
Thank You
You guys are the greatest
Your help is much appreciated
Did I say Thank You
Mark
No problem. I wish there was the internet when I had my problem many many moons ago. I almost didnt respond to this but I really felt for you! Glad it is fixed.
    J.P.L
    J.P.L
  • Who's Online   6 Members, 0 Anonymous, 451 Guests (See full list)
    • Maybe, but it seems he is the only one that has backed up data to prove what he is stating. I think he is doing this more because he enjoys it and wants to get the information out to us. He's got the knowledge and access to the proper equipment and having the funds doesn't hurt.  I would love to do what he is doing and would do it if and when I hit the Powerball.  I'm not a Tribologist by any means but love to learn what I can.   I would bet there would be doubting people out there if a completely independent lab with high quality work and highly respected in the automotive industry, put out information like this.  The world can't be pleased, one just has to take the information that they are given, do more of their own research to find actual lab data to back up what they are trying to figure/find out.  Most don't bother, they just want to believe what they first see.     I don't have the minimax but my 6.2 in my 2019 Silverado with 64k miles shows excellent UOA results with 0w-20 and for my own purposes 5w-20.  Since not much of a change using 5w. I liked the data sheet information on the SS 5w-20 and figured I would give it a try.  Still the same viscosity at 100℃.   In the end we all just do what makes us happy, life is too short to get upset over trivial social media.   On a side note, I do feel GM has dropped the ball and just cares about the bottom dollar and not quality anymore.  "Like a Rock" has been long gone.  Seems "Built Ford Tough" has as well.
    • Better than stock but that's like putting lipstick on a pig
    • Hello, my 3 month old Sierra Elevation wont recognize a trailer with electric brakes? All the lights work correctly, but no power to the brakes?   This is the factory installed brake controller. If you manually push the knob, the display shows the power % but does not light up like my 2022 silverado.   I have an appointment with the dealer, but was checking to see if anyone else has seen this issue.    Thanks,
    • Been using SS 0w-20 from new, but wanted to change to the 5w-20 because I liked the data on the data sheet, to me it seems like a little better product. But as you can see, not much difference. This is also with running a mix of 10 gallons E85 to a tank topped with 93. It isn't a flex fuel vehicle so any higher I get a CEL for running lean on both banks. Yes my mileage takes a hit. Instead of 20 mpg I normally get on trips I get 17mpg. This is also using EaO17 filter.  What is amazing is I have the AMSOIL cone filter on it since I have the GM Performance intake installed and that air filter has 44k miles on it.  I just take it out and shop vac it off once a year.  I use the upholstery tool on my shop vac.  Works well.
    • So, lot's of googling and reading, and a trial fit found, that indeed they hit the newer fatter caliper. I did some re-testing today, and found just 3/16" worth of washers was enough for the wheel to spin freely. I added 2 more on each, and again it spun freely. Tested lock to lock with the 4 washers, about 5/16" not quite the 3/8" Im considering, but pretty close. No issues. I've been looking at the BORA .375" spacers and using extended lugnuts to get back lost thread due to the spacer. All the ET lugs I've seen are all .33" reach inside the wheel lug holes. For those that don't like spacers or think they're unsafe, I think it depends on what type of spacers you're using and making sure you get good quality hubcentric ones, and if you're using bolt on ones, regular mainenance, checking the spacer lugs. Not wanting or needing that much spread. Looking for the minimum that will let me run these rims and tires.  it does look to stick out a little, but I really want put these on. and use the stock all-terrains in the winter.
