upgrade non-bose to bose-lux???
Hi, I have an 06 Tahoe with the non-bose radio/cd/8spkr system. I would like to upgrade to the bose-lux system. I know the difference between the lux and non-lux in older years, but I don't know if the factory option for the bose system for this model year was the lux or non-lux. The confusion is that the non-lux was a "dump amp" and the lux was the digital "smart amp" (ie it takes signals from the radio head when the user adjusts vol, tone, fade etc., and thus the radio head was a required component of the "lux" system) and the GM brocure for the 06 tahoe stated that the Bose system included a "digital 6-channel" amp.
Note that my truck does not have the center console and thus I would have to locate the amp and sub in another location, since it is my understanding that they are normally installed in the console. I can handle custom work like this, but I would need help in figuring pin-outs and location of certain wiring such as the Class-II bus. I realize that my speakers are not Bose, so I would have to upgrade them as well (although it probably doesn't need to be Bose). I believe that the rear pillar speakers are wired in parallel with the read door speakers and thus they would need to be directly wired into the amp. I would also need help with compatable amp and radio head part numbers.
So basically, I would like to know:
1) Is the '06 Tahoe Bose option the "lux" amp?
2) Can I upgrade to the Bose lux system?
3) Has anyone seen a "how-to" ariticle on doing such an upgrade?
Thanks ALOT, Dean
Hi
There is help for this as it has been talked about in detail on this board. I can't seem to find the link, but it has about 35 pages in it and gives you wiring diagrams and pinout locations. If you can find it the information will be in there.
Hope it helps
Jerry
Hi Guys,
Thanks for the link, but I think that 'linda' had the bose non-lux and upgraded to NAV/CDX/LUX system. My goal is less ambitious, but maybe not likely either if it turns out that without the Bose system from the factory, I may be missing a ton of wiring???
Thus, I am still in search of answers to my original questions if anyone out there can help me?
Thanks,
Dean
Dean,
If you look at post #20 here:
http://www.gm-trucks.com/forums/index.php?showtopic=28030
linda says
the BOSE system is a MUST! you have to have BOSE audio system from the get go. If not...you will spend WAY to much for the retrofit.
That's not my words -- I'm just pointing that out.
As far as your original questions:
From everything I've read, I doubt it. Seems the "lux" only comes on escalades and denalis. But they say there would be a Y91 or Y92 option code in the glove box if it is.
I'm sure anything's possible. I just wonder if a non-Bose system even has an amp. That may be why linda said what she did -- you might have to add the amp and all the associated wiring.
I'm sorry, but the link I posted before is the only thing I know that's close.
Glenn
Hi Glenn,
Thanks for the post. The non-Bose option does not have an amp. I understand that older model Bose non-lux had a 4 channel analog amp while the Lux option had a 6 channel digital amp. Since the '06 Tahoe brochure stated that the Bose option was a 6-channel digital amp, it seems that they could have installed such a system in that truck and thus MAYBE there is some portion of the wiring in place already??? Man it sure would have been better if I could have found an 06 with this option, but by the time I bought it there were almost no 06s left!
Dean
I wonder how the JP system works on a non-bose vehicle? Don't those TNR head units (lux or non-lux) require an amp?
Dean, I'd make sure before buying.
Glenn
Hi Glenn,
Dean
yep, as you said 2003+ non-Bose systems utilize an amp internal to the head unit itself. 2003+ non-lux Bose amps use a 6 channel analog amp. Front left, front right, rear left, rear right, and left/right sub channels. (sub is a dual voice coil driver) Rear speakers are full range, front speakers are full range, the pillar tweeters are wireid in parallel with the front door speakersa nd have an inductance capacitor wired in to act as an el-cheapo cross over so the tweets only get high freqeuncy sounds. Sub gets only low frequency stuff, there is a passive crossover inside the amp.
2003+ lux systems use the exact same speakers and sub as a non-lux system, but they use an 8 channel "digital" amp. front left, front right, rear left, rear right, 2 sub channels, and a left rear twiddler and right rear twiddler. The amp has an internal DSP, active crossovers, and a DLC chip so it can communicate and be controlled by the Class II data bus. rear speakers are full range, but have a low freq cut out. Front speakers have a low end cut too, and are rolled off into the sub. They are not full range. Sub is crossed over to perfectly match the front door speakers. Tweeters are wired the same, with the capacitor acting as a x-over. Rear twiddlers (d-pillar speakers) are crossed over in the amps DSP so they only get high sounds. Lux amp is much more pwoerful with better quality circuits. 50 watts RMS per channel at 2ohms per channel, twiddlers are 15 watts, 2 ohms, sub is 100 watts (50 per coil), 2 ohms. Yes, thats what the lux amp is, its not a big Bose secret anymore.
2006 Tahoes did not have the option for a lux amp, it was probably a typo. :happysad: Only vehicles to come from the factory with a lux amp were the 2003+ Escalades and Denali's, the 2003+ Sierra Denali, and 2003-early 2004 Hummer H2's. Early 2004 H2's switched toa non-lux amp due to problems they had getting the lux amps to play nice in an H2 chassis (non c/k chassis) for some reason.
Any 2003+ Bose system, non-lux or lux can have the lux amp added to it. No additinal wiring is needed. All you have to do is rewire the amp connectors (pull the pins out and put them in different positions) and reprogram the head unit, and plug the lux amp in. Reprogram the head unit BEFORE you plug the Lux amp in/rewire the amp connectors. You have been warned. :happysad:
  • 7 months later...
Okay. I've read a lot about the lux amp upgrade with the TNR, but what if I don't upgrade to the TNR and keep my existing in-dash 6 disc /XM, OS and RDS. My '03 SLT LX has the std. bose amp and if I want to upgrade to the lux amp will the head unit need reprogrammed along with changing the amp wiring harness? Or is there more involved?
    • When I had a Bumper subscription for a few days when I needed to run title histories on cars I was looking at, I decided to look up a few of my old/past vehicles.   My 2015 Silverado was still actively registered and it last sold in 2024 with 160k on the clock. No idea if that's on the original engine but someone's keeping it on the road or the original AFM stuff is still going.   It used 0w20. I remember feeding it Mobil 0w20 AFE for the first 30k of its life on <5k OCI's.
    • I can't say I have ever heard of someone getting that type of mileage out of a set of tires even though they rotated on a regular basis but without a doubt if the front end gets wear and those tires are no longer able to track straight it scrubs them off, and driving style and road surface make a huge difference as well.    However that is not what prompted me to comment as it was the new tire theme of sitting in storage waiting to be used scenario. I am sure some tires can last for quite a while in storage if its not too warm and out of the sunlight but unfortunately some tires the way they their rubber compound is formulated they can age and dry out even in a reasonably decent storage location. My brother ran into this maybe three years ago when he was looking at the tires that were on his dually truck and a combination of wear on the rear ones and noticing that the front tires had some cracks around the sidewall of the tire not far from the bead but he had replaced only the front ones not long ago with 2 of the remaining 6 he had left from the initial two sets of takeoffs he had all bought at the same time .... 10 years ago ! ( the years fly by, a truck that only gets used a bit to haul a camper during the summer and sits in a shed for a large part of the year ). That second set of 6 tires, two he had put on the front prior like I said and they had very little wear but those cracks were now present. So we go into the shed where the other 4 tires had been stored all this time and every one of them had the same cracks in the sidewalls and so in the end it amounted to throwing away 6 brand new but 10 year old takeoff tires into the dump that he got a deal on at a tire shop because they aged out. They were a Ford factory equipment BFG tire and those tires did not age well compared to some tires I've seen far older then that and did not show that type of aging. True, they always say up here anyway that 7 years is sort of a limit for age by rights, we don't have the intense prolonged heat that many of you have down in the states that just cook tires and depends on where the vehicle sits when not in use. GB, another words maybe had you bought a set of tires to store it would have been fine as long as you used them up fast enough but there are no guarantees when it comes to rubber, tires or of that other type stored in some guys wallets 😆
    • 2020 2500 HD...I had some trouble getting the key into the ignition switch but went in fine after applying some extra effort. Since then, the door chimes when open when the key is out of the ignition. Also, when I lock the doors with the switch on the arm rest, the driver door locks but then unlocks. (I can lock everything fine with the fob) The message on the little screen displays the "Engine Hours"...kinda weird.   I'm guessing something happened to the ignition switch and it thinks the key is still in there. I unplugged the batteries for 20 minutes, no change. There are a number of videos on YouTube but nothing I can find that address this specific issue. Ideas appreciated, thank you.
    • Based on what I can tell, yes.   As for updating it, its a mixed bag.  Updates do fix a lot of issues, but occasionally can create some oddities.  They do more good than harm though overall.     Here's what the most current one does and a  V171 Improvements Important: Improvements will vary by model, build configuration, system, and sales region. Not all vehicles have all features. OnStar and Wi-Fi may not work after remote start CarPlay may not automatically reconnect Part of the Driver Attention messaging screen may be in English even though the language is set to something else XM may not work After a dead 12V the radio may set to Arabic at each startup Bluetooth contacts might not be able to sync with the vehicle During an OTA the 12V battery may drain Customer might see a screen telling them to return to the dealer After changing the Wi-Fi SSID or password a device may not disconnect If a device is connected on the 2.4Ghz band, nothing will connect to the 5Ghz one, which could show as slow Wi-Fi speeds Customers might have noticed Wi-Fi dropping in certain areas and reconnecting later Customer might see the top of the screen blinking during Android Auto Android Auto may not connect CarPlay audio might momentarily cut out The "Add Phone" button may be grayed out The radio may not start up   V167 Most Notable Improvements:   Outside Air Temperature is incorrect. -You may see a popup message for Engine Shift. (Corvette Only) After changing the exhaust sound they get a popup that "mode change not applied", even though it was. -When changing volume, the volume bar is for Traffic instead of Audio. -(Corvette Only) Improvements to the placement of buttons and text. -If the customer receives the message "Apple CarPlay Could not connect", the cursor might move in the opposite direction than expected when using the control knob. -Android Auto automatically starts playing their music, even though they have turned that off in settings. -Intermittently they have a red OnStar LED with no OnStar function and/or no audio. -The minimum length of the Wi-Fi password was increased to 12 characters. -The popup message "Driver Attention Check, check your mirrors or Super Cruise will shut down" may not have come up on the display when it should have. -Startup animation added for 20th anniversary of the V-Series on Cadillacs. -The Navigation app received location improvements when going under long underpasses. -In the Navigation app there are filters for charging points that the vehicle cannot use.   V164 Most Notable Improvements Most notable improvements contained in this release may include: Apps Intermittently, an “SD Card Removed” message will pop up in the Navigation app. While in the audio app, the radio may stop working. Trailer Tire Pressure sensors may not be learned in the Trailer app. Not being able to return to the home screen while in the Camera app. After an ignition cycle, the radio might go to a black screen or stop working if using Sirius XM. Spotify icon truncated on Audio app.   SXM When changing power modes with the ignition switch, the HVAC pop up might appear. During startup, the radio will show the brand splash screen then go blank. Receiving a confirmation pop-up when changing drive modes. A “Return to Dealer” message may appear on the radio screen. SuperCruise setting toggle may not work. System After an ignition cycle, the radio might go black or stop working if using Sirius XM (SXM). Settings When performing a factory reset, the radio may stop working. After performing a factory reset, the radio may stop working when trying to switch users. When trying to go into the Language section quickly after startup, the radio may stop working. Projection Wireless CarPlay cannot be connected after unpairing another wireless Android Auto device. When the Android Auto screen comes up to connect wirelessly, the screen may freeze if the Cancel button is pressed. Removed the Apple CarPlay Cannot Connect screen when a device fails to pair during the autoconnect process. CarPlay information may not show up in the audio app. Near Field Communications (NFC) chime may be heard when NFC does not work. The Cannot Connect screen does not pop up after the first connection on wireless CarPlay fails. Apple CarPlay is now functional in Guam. Over the Air (OTA) When a software update is cancelled, the downloading logo may still be displayed. Energy When using the Energy app, the radio may stop working. When plugging in the vehicle, the display might show “Now” instead of “Charging Upon Plug In.” Instrument Cluster Voice recognition can be started while on an OnStar or phone call. When downloading contacts, there is a progress bar and circles on the Recents page of the cluster. The temperature on the cluster and the display may be different. After receiving and ending a call on the secondary paired phone, the cluster may get stuck on the phone menu. Bluetooth Intermittent Bluetooth connection loss.
    • Looking for help troubleshooting a metallic like front end rattle. Figured I’d see if anyone had thoughts before I schedule an appointment with the dealer.   The rattle is fairly loud and occurs primarily when the front driver side wheel hits a bump, even fairly minor road seams. Sometimes does it when the passenger hits a bump but I don’t believe when the rear hits. Rattle still occurs when foot is pressing brake peddle so I think that rules out the caliper rattle I’ve read about. I’ve also checked the running boards and they are tight.   Most noticeable at slow speeds.    Any insight is appreciated.
