4L80E trans Service Part #s needed
24 hours, only 9 reads, and 0 response? I'm really surprised, as I thought the 4L80/85e was one of the more prevalent GM truck transmissions.
I spent a lot of time googling yesterday, but I'm still not coming up with the definative GM part numbers for the transmission service filter and seal that I would need before ordering accurately from GM Parts Direct.
Model Year 2005 4L80e (RPO MT1):
Filter/Screen GM Part #: ?
Filter Neck Seal GM Part #: ?
Replacement 4L80/85e 4x4 pan with built in drain plug GM Part #: ?
Any help would surely be appreciated!
I just go up to Advanced Auto and buy my filters and such for trannies and never mess with part numbers (a lot do not either) As far as pan, I cannot help you there other than my 2000 K3500 has a drain plug on the pan from the factory on its 4L80E so it you get one for that model year, it will have a drain plug (I am sure there are other years/models too)
