What size is stock exhaust?
What size is the stock exhaust piping on these trucks? If I buy a muffler what size inlet and outlet do I want to buy? 2.25 inches? Thanks.
I think my 2000 5.3l GMC came with a 2.25" tailpipe.
I had the shop use the factory diameter and my current setup is 2.25" - unless they screwed up :driving:
I had the shop use the factory diameter and my current setup is 2.25" - unless they screwed up :)
It should be at least 2.5 inches OD
