Checking for head gasket leaks
I posted another topic in a different thread about my truck problem.
But...
I wanted to know specifically about checking for a head gasket leak vs. intake manifold leak etc.
I wanted to know if the mechanic/technician can pressure test the engine while everything is assembled and see if in fact there is or is not a leak and where it is (if it's a head gasket).
And...about how much does this "test" cost and what does is done for it???
I was going to have it checked (tested) by the same people who dump the old green radiator nonsense out and refill it with something better like the first mechanic should have done.
I only have about 6 days and I'm moving...wish I would have noticed this sooner. :)
Thanks,
Michael
But...
I only have about 6 days and I'm moving...wish I would have noticed this sooner.  :chevy:
Thanks,
Michael
Are you saying you intake gasket is leaking with the green crap? I can't believe that...Stop the presses.. An if you read the messages here I thought it was only that evil Dexcool. :)
Just have a pressure tester put on it. Anyone with half a brain ought to be able to do it.
Well, I don't blame Green Coolant or Dex-Cool for any corrosion problems. The water is what I blame...and that is really unavoidable in all reality unless you can stop corrision with some other chemical. My motorcycle has corrosion on it because of the aluminum parts in various places, and I know it has nothing to do with coolant of any sort. Iron produces rust when it corrodes, all other metals are just corroded but I don't know of any special names for the process in each metal. Anyway, it is the water however the process can be enhanced by other chemicals breaking down. My motorcycle uses NO coolant, it is air cooled...even the oil cooler...It is the moisture in the air and the dirty water that sits on it as the fog rolls in because I have no garage for it... :chevy:
Back to the truck...
The real reason for wanting the orange fluid (or extended life) back in is because I will be travelling through the Mojave Desert in the near middle of the summer her in about seven (7) days. After that I have a few other hot dry climates to drive througn all while the truck bed is filled with household goods and while pulling a small trailer with my motorcyle.
I don't know much about the yellow coolant but if it dissapates heat faster, I want some if it is "compatible" with my 1996 5.7L engine.
I don't have the time to completely rebuild or clean out a radiator, so I guess I'm going to shortcut the whole ordeal.
I will most likely go with Prestone Coolant that has the rust inhibitors and lubricants.
Now, about that head gasket...
I will have it tested this week to see if it is a problem or not.
If it is a problem...what is the approximate cost estimate for replacement...
And...
How much time (will it delay the trip much if I leave 17 June and bring it in on the 13th of June)???
Thanks again...
If you *do* end up having a marginal cooling situation during your trip, dropping your speed by 5 or 10 mph will reduce the amount of heat your engine's generating, making your marginal cooling situation more adequate. Keep that in mind. Beats overheating.
Intake coolant leaks easily diagnosed with a pressure tester. Some places perform this cheaply....around $19.99, others charge flat rate. '96 5.7's are notorious for eating up the quick disconnect heater hose connector on the manifold or the hose end itself being a formed aluminum alloy piece. Galvanic corrosion is the culprit. Routine coolant system checks will help determine when to change the coolant.
Head gasket checks are a little tougher, but I have good luck using Block Check, a chemical additive in the coolant that detects hydrocarbons from combustion by-products. The way they get into the coolant is from a head gasket leak. Some mechanics use their gas analyzer or smog machine to detect HC's in the coolant too. Holding it over the filler neck and taking readings.
I just had the wife (ASE Master Tech) pull the heads off my 98 GMC and check for valve stem clearance issues in three days. One day to pull it down, one day at the machine shop, and one day of reassembly. About $1700 if I had to pay for it fully.
    • I know when I was looking around last year to see if someone handled Amsoil gear oil to buy at the retail level which of course means full price. I found an independent shop that works a lot on GM/Duramax pickups and they did not bring in the 75W-85 as they just stuck to the 75W-90 for the front and rear as a standard practice for the HD trucks which makes sense anyway for the higher hp/torque diesel and pulling heavy loads in four wheel drive. I haven't changed my diff oils yet but still plan on using the 75W-85 for the front diff as I highly doubt I will be beating on the truck and figured for my use type the bit thinner oil would be to my benefit for the winter for that slightly less drag. Very different weather here all winter vs northern Washington near the coast, that's for sure.
    • Ok that confirms the extra quart theme they are still going with which must mean they have noted some initial use more so then some engines and probably the bigger factor in all of this probably isn't the engine so much as its the insane distance or OLM that lulls a lot of the driving public into driving their new vehicle off the lot and not even doing one short interval oil change because the manufacturer doesn't say different and if the dealer follows that logic as well. Selling the rarely needing to be serviced concept seems to go over well with the public that wants to get away with as little as possible for dollars spent on the vehicles maintenance and I bet there are 3.0 engines just like other vehicles out there that never have their oil checked by the owner which goes back to why they probably felt the need to add that extra quart to avoid a costly theme.    Speaking of cutting filters open, it was probably over two years ago now that a youtuber who buys vehicles to do longer term reviews and pulls a fifth wheel through the mountains of Colorado on summer trips and that becomes part of the testing. Anyway he had a GM HD with the 6.6 gas and a Ford 250 with the 7.3 gas at the same time and of no surprise the Ford had more power etc but somewhere along the way in the few thousand miles he put on the truck, he changed the oil and was seeing glitter and cut open the filter and yeah, things were not looking spectacular. The truck about that time or soon after seemed down on power compared to what it had been and then threw some engine code, I expect the cam/lifters were failing and so he brought the truck back to the dealer and made some deal to get out of it as he knew it would sit for months waiting on a new engine as they were so backlogged at the time. He kept the GM for some time after that using it exclusively until he sold it after buying his next vehicle to do a review on. Definitely the filter can tell a story when things are starting to go sideways, but it would be a sickening feeling to cut it open and be faced with an ugly mess like that and be running a magnet through the pleats and the oil on the dirty side of the filter and see all the fines sticking to the magnet.    The dealer may have some ideas based on experience as to where that coolant smell is coming from, I would imagine if they can't find it but its smelling they would put dye in it to they could give it a run cycle and use the black light to see where it pops up, if its a hose connection, water pump, rad or even a head gasket etc.
    • Good looking truck, suspensionmaxx looks like a solid option
    • Thanks for the info, im considering a leveling kit or 4" lift kit.
    • charm.li (website) has the vehicle-specific diagnostic procedure for that code, you can use to find what the cause of it is.
