i want to make my 2000 sierra look a lot more up scale inside.
because the whole inside is dark black plastic. and i was thinking of painting parts of the dash chrome with gloss black using areosals(vht, duplicolor, krylon etc). has anyone used chrome spray paint? pics? opinions on what it would look like.
I think I've read where some users have used the chrome paint then cleared over it. No first hand experience though.
I would think if your are doing the dash with chrome spraypaint, it'll probably look/work pretty good.
Like Smooth said, clear coating it will certainly help (for both look & wear)
Just be sure to use many light coats, not a couple heavy ones. And clean the dash really good. Soap & water should work good enough.
Good luck & post some pics once the job's complete.
  • 3 weeks later...
clean real good (dawn work well at removing hand oil)
clean again with some paint degreaser (alchohol ect.)
scuff up real well with scotch pad or sand paper
re clean to get off sanding dust
put under hot lamp for a hour or so
re clean with paint degreaser
apply adheason promoter per instuuctions
dust with paint (dusting is very light coats so light sometimes you think you didn't realy paint it)
re dust till it's covered well and the 2 times more.
wet sand with 2000 + paper
tack cloth
dust again
0000steel wool till it shines if it dosent shine up
tack cloth dust shine till it comes out the gloss you want
the shine will help determin the depth created by the clearcoat
now comes time to dust with clear the number of coats of clear will determin the true depth for a bright look 3-4 should work medium 5-6 7-10 give mirror like looks over 10 and some clears start to yellow
now comes the final sand
800 will provide prolly the best shine more angles in the clear to get light to the crome and back in your eyes
1000-1500 give the gloss look
anything over 1500 will reflect to much and darken the crome
thats how i like to do it
clean spray paint clean spray clear will also work
other options are apliques and replacement trim pieces. in wood carbonfiber and chrome or brushed allumininuunioninm
    DM22
    DM22
  • Who's Online   5 Members, 0 Anonymous, 1,692 Guests (See full list)
