Prius Racing
ZZebes
Well Ladies and Gentlemen I have officially been sent the greatest Forum topic anywhere by one of our other members. This is a topic from a Toyota Prius forum, Ohh it gets better, about how there prius's are running low 17's in the quarter and beating M3's and Mustangs etc, etc, etc, Bulls*** and fun
Prius Racing
Enjoy and thank NewFZ for the link
Prius Racing
It kills a good 30 minutes reading all the BS they throw around, but it gets really funny as they all turn on each other. Pfft, who needs hybrids when you got gas guzzling trucks.
Man, I wish our trucks got the specs listed in the magazines like the prius' do...amazing they say one thing, get corrected, then try to say they didn't say it.
Whats that TBSS run wingnut?  I have heard of them doing mid to high 13's, is that right?
That about right. There are a couple of guys in the 12's with nothing more than a CAI and a tune...But that's rare...Most are mid to high 13's.
i love the part when they were talkin about toppin out at 106 , or 108 or somethin like that , hell i was on 75 north from tenn last week cruisin at 105 at times , and there talkin like its ungodly fast :):D
Would you want to go over a 100mph in a go cart with 4 bicycle tires?
hmmmmm, actually yes i would...LOL. That would be pretty cool.
I whooped the pants off a go-cart with bicycle tires in my prius yesterday...oh, wait, wrong forum...
This sort of reminds me of a story I heard about a guy who walks into an Auto parts store and says to the clerk "I need a gas cap for a Yugo" The Clerk replies "Sounds like a good trade"!
Want a really fast car? Electric has the possibility to be alot faster than gas. An electric motor at each wheel would be devestatingly fast. The motors are instant on and up to rpm almost instant. The problem arrises with range. These things are dead after a 1/4 mile and need recharge. Check out this site
National Electric Drag Racing Association
GAS GUZZLERS TILL I DIE
but seriously i dont think i could go without my v8 rumble
  • 4 weeks later...
Electric! Cool! I never thought of that! How long do they make extention cords? I could probably hold a good 2000 feet of it in my bed! :)
    Brendan C
    Brendan C
  • Who's Online   6 Members, 0 Anonymous, 1,086 Guests (See full list)
