Corsa: Sport vs. Touring
Hi guys, I've narrowed my exhaust decision down to a Corsa, but I can't decide between the sport and the touring. On their website, they both sound pretty much the same. I was wondering if there would be any difference in power gains with the two. I want something that doesn't drone, yet has a nice throaty/race car type sound. I do not want that raspy red neck cherry bomb sound. I have heard some on here say the sport is pretty loud. I want it to sound good, but I don't want to wake the neighbors everytime I leave the house. Thanks, all help is appreciated.
I'm looking at getting a Corsa system too. I sent Corsa a e-mail with pretty much the same question you have. I have the LQ9 6.0 and I didn't want something that would shake the neighbors windows when I started the truck, I just wanted some with a richer exhaust note than the stock exhaust. When they e-mail me back with their suggestion I pass it on to ya.
Ihave had the corsa Touring on my 2000 1500 Ext Cab 5.3 4x4 for two years Love it. I Junked A Magna Flow system that Put a reasonance in the cab that would give you a head ake after 10 minutes. magnaflow customer service said tuff if you don't like it go buy some other exhaust.
Have the sport on my truck. Its a good bit louder in a good way IMO. Go for the sport!!
The touring muffler has a small amount of Dow Corning packing material in the end to quiet it down. The sport has nothing in it but some baffles. So overall the Touring kit will be alot quieter. These are stright through mufflers!!
This gives a good idea of what the sport muffler looks like inside. Not exactlly what it looks like now but close.
I had a Corsa on my 95 Vette and it was nothing short of incredible. There was a guy on ebay recently who needed to move some Corsa systems and I picked one up for my new 2006 K1500. I couldn't resist for $400 (or there abouts) shipped. I notice no performance gains (I also have the K&N intake). Sound wise it is very similar to the one I had on my Vette in that it growls at idle, is quiet at normal cruise with no resonance, but put your foot into it and it roars! It actually may be just a bit too loud tho if you drive alot of hills or mountains and the engine is frequently kicking down a gear.
I just bought #14270 Sport Cat Back Dual Exhaust with Twin Tips. I love it. The sport exhaust sounds more racey. the touring sounds more mellow. i did the install with 2 friends in less than 3 hours (i broke one of two bolts - had to punch it out). it wont wake the neighbors when you start it up... it goes high for a second then idles well... if you dont GET ON IT when you leave, you wont have a problem. when you GET ON IT, its loud. but sounds great.
Is this a sport or touring?
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
