radio problem...
ok, i have a problem with an '00 express LS.  it has the am/fm/cass ETR radio.  my problem is that it seems to skip stations when you use the seek feature.  is this a common problem??  can i fix it??  the radio seems pretty crappy in general
it skips almost all of them though.  if i go back very slowly it will sometimes work.  i pick up these stations fine in other vehicles.
you might want to check your antannae connection, maybe try an aux. antannae (sp?).
I usually find this problem in Cadillacs.
  • 1 year later...
yeah, my radio will pick up fine if you use the knob, but on the scan, it just scrolls the whole way through??????
I have exactly the same problem!!! Even when I manually dial into the strongest station in town, the reception is pathetic!!
Do all Silverados have this problem or is my antenna just not connected? :(
I have the same problem with my 2000 LS Ext; pathetic reception, seek not functioning .... and today I found out why!!!
When I bought the truck ( 5 days ago ), I thought the antenna was in the windshield because I couldn't find it anywhere else. Then I purchased a repair manual. I looked up how to change the antenna...read about the location and found that the antenna should be just behind the hood on the pass side just before the hood ends (side to side) under the plastic trim.
I basically found a stub... where the antenna used to be attached. It was a clean break.. it looks like a big rivet. I visited a local dealer... found two other Chevs with it missing also. The dealer didn't know anything.. he just said that's how it is. Well of course the reception is poor with no antenna!!! He's changing it next week.
I hope this is the solution for all of you with the same radio problem!!! :)
