Mobil 1 Vrs Mobil 1
I still use the regular one also. 5-30 change every 5000 miles with a Delco filter.
Regular Mobil 1 5w30 and ACDelco PF46 filter whenever Oil Life system advises change time (or 6500 miles, whichever is first). I don't trust an oil that is bulging with additives, I prefer just the standard great Mobil 1.
Just turned 1,100 miles in the '06 and will be switching to regular 5/30 Mobil 1 tomorrow, like I have in all my other vehicles. Change every 5-6,000 miles.
Why is that synthetic is synthetic? Do you have information the the other is bad or is this just an opinion?
Regular Mobil1 5W-30 and an AC-Delco PF59 filter for me.
I used the "Extended Performance" once but it seemed to get dirty real quick for some reason,you know it just seemed like it was turning "darker" or "blacker" quicker than the regular Mobil1,Plus I don't think the "Extended Performance" oil meets GM specifications,At least it didn't when I ran it last spring,but that could have changed since then.
:cool:
That, and--at least in my case--I noticed that my fuel economy dropped a smidge after trying the M1 EP oil...
rich,
You still get the PF 59 filter?I use the PF 61 now that I can't get the 59.
Steve
Btw:I use the Reg Mobil One
rich,
Steve
Steve,
Yea,I still got about 15 PF59's left,When I heard they we're doing away with them I took the last case we had at work,Plus theres an auto parts store in town that still has a bunch of them so whenever I'm in town I always stop and pick one or two up while they still have them,I should be good for awhile :cool:
Rich.
P.S. The PF61 is what some of the guys at the dealership are using also in place of the PF59.
I use the regular one, 10-30, change it every 6 months (7000km) with a high quality filter (K&N or Amsoil)
I hate to tell you this but K&N is not a high quality filter. I used to be a religious K&N man myself until I found out they really don't filter much at all. I'd use K&N on any race application that needed maximum flow but for non-race applications, AC Delco Ultragard, Mobil 1, and Napa GOLD filters are all outstanding filters that actually filter VERY good. They all flow pretty good for normal driving and if you ever need to FLOOR it, you have the bypass valve of course to give you that immediate emergency oil flow that'd be unrestricted by the filter.
There are 2 Mobil 1 oils now. the original and this new extended train one ,What do most of you guys use ?
Scott
dont ya love oil threads??
sitting on a 93 GMC that has 244,000 miles on it at last count, most of them miles on synthetic oils of either the mobil or castrol varieties, and any old oil filter you care to think of.
oil got changed about every 15 to 20 thousand miles.
so you peeps who get uptight over brand, or what kind of filter need to relax cause it really dont matter
Beg to differ. The last oil filter study I saw rated Mobil 1 and K&N oil filters in the top 4 of oil filters. Both the Mobil 1 and K%N filters are made by Champion in Albion, IL.
Google some for oil filter comparison and you can read quite a bit on it. Not trying to flame, just pointing out I have seen tests rating both very high. Fram filters seem to be one of the worst with their cardboard endcaps.
I run Mobil 1 traditional and Mobil 1 or KN filter every 5K. Up to 173K so far.
    bellssn690
    bellssn690
  • Who's Online   4 Members, 0 Anonymous, 705 Guests (See full list)
