Help with exhaust
Im looking for exhaust pics, clips,, any kind of information about exhaust for the 6.0 2500 HD. I have a 2001 HD with dual flowmasters that were on it when i baught it. And the mufflers rattle from poor installation and the pipes are about to fall off.. But the thing i hate the most is how much the mufflers hang down under the truck frame. You can see them from any angle and i just dont like it. So help me make a decision! thanks ahead of time for the info.
I think the Magnaflow system is probably the best.
I don't have any experience personally, but that seems to be the general concensus that I've seen over the past couple of years.
It isn't too loud, won't sound like crap, and flows well.
Here's a recent post for you: http://www.gm-trucks.com/forums/index.php?showtopic=54105
I hope your right. I just purchase the 5"x8" with dual inlet/dual outlets (12469) off ebay for $90/shipped. Can't wait to get it on an make this truck sound a bit meaner. :cheers:
