tire screech when turning
hi guys/gals...there's a screeching sound when i make hard turns..like the sound you get when you're turning in a parking structure. what is this? i've had the steering fluid topped off just the other month..thanks in advance :)
I'm probably wrong, but I'll go ahead and throw it out there. Could it be your tires? Mine are bald and they screech if I take any turn faster than 10 mph.
1. Is the screeching coming from under the hood?
2. If #1 is yes, during the turns is the steering wheel all the way over to the stop?
If both are no, than it will more than likely be your tires. :crackup:
If both are no, than it will more than likely be your tires. :driving:
sounds as if the sound is coming from the tires somewhere, not under the hood. i hope it's just the tires. and no i'm not turning the wheel all the way..its kind of like a "burn rubber" kind of sound..maybe i'm turning too fast :crackup:
My truck does the same thing.
Drives me nuts! Sounds like you're doing donuts when all you're doing it turning into a parking spot.
By the sound of it...pardon the pun...you just need some new skins. Invest in a nice set of tires and you'll be good to go. :crackup:
The tires on there now are almost brand new....were only used for 4 months when I put them on this spring. I used them 3 winters ago and then switched to real winter tires. Kept these Firestone tires (OEM) and put them back on this summer.
They started to make noise only a couple of weeks ago. :crackup:
Try rotating the tires and see what happens, that should help make sure. It would suck to get rid of a set of tires with good tread on them...but there are some bad tires out there. I have a set of Bridgestone Duelers A/T 265/75/16 and love them.
    Brendan C
    Brendan C
  • Who's Online   6 Members, 0 Anonymous, 1,086 Guests (See full list)
