tailgate down: better mpg?
will leaving the tailgate down really give better mpg? i've tried it and i dont know if there's any significant difference if any. and hey...there are no stupid questions :crackup:
You actually get better mileage with the tailgate up. See: Mythbusters
Basically, with the tailgate up the air creates a "bubble" if you will in the bed which the passing air flows over, while when it is down it drags allong the bed.
Mike
Mike
This is only true of short-box trucks. Long box trucks, the tailgate works against you and lowering it actually can help. Since most trucks are short-box anymore (people buy trucks to ride around in, not use like trucks), they tested only a short-box truck on Mythbusters.
That being said, the difference is actually not very much (like .5mpg).
Mike
I second that!!!!!!!!!!
Saw that episode also. That was interesting.
Keep the tailgate up.
Long box or short it does no makea difference. Go here for the GM test.
http://sitemaker.umich.edu/um.gm.truck
And this should convince you if nothing else.
I'm an aerodynamics engineer. When I was in the U.S. Air Force
a few years back, I worked with folks from the Lockheed
low-speed wind tunnel. In the 1970s, aircraft production went
into a slump, and Lockheed started looking for other customers
for its wind-tunnel services. Prime candidates were the auto
makers, and Lockheed was successful in convincing Ford, among
others, that the wind tunnel would help them reduce drag and
wind noise on their vehicles. Needless to say, in the past
15-20 years, Lockheed has learned a lot about car and truck
aerodynamics. Anyway, they actually performed drag tests on
pickups with the tailgate both up and down, and found that
drag was actually LOWER with the tailgate CLOSED! This ran
counter to their intuition (and yours). The reason is that a
closed tailgate sets up a large "bubble" of stagnant air that
slowly circulates around the bed of the truck (we aero types
call this a "separated bubble"). When air approaches the truck,
it "sees" the bubble as part of the truck. So to the air, the
truck looks like it has a nice, flat covering over the bed,
and the air doesn't "slam" into the vertical tailgate. If
the tailgate is open, or replaced by one of those "air gate"
nets, however, that nice, separate bubble in the truck bed
does not form (it "bursts"). Then the air approaching the
truck "sees" a truck with a flat bed on the back of a tall
cab. This is a very nonaerodynamic shape with a very LARGE
drag. So, believe it or not, it's best for gas mileage to
keep the tailgate CLOSED. Hope this information is helpful.
Ed Fitzgerald, Research Assistant, Dept. of Aero/Mechanical
Engineering, U. of Notre Dame
Yup....exactly what Jamie and Adam said. I love Mythbusters.
Notre Dame eh.....think they'll be any good?
They did do a "fluid" test too.
Now what about taneou(sp?) covers which claim to improve mileage?
Mike
I'd think those too would hinder mileage. Seems like the flat surface would "burst the bubble" as well. Definatly be interested to see some results.
  • 3 weeks later...
I've seen four instances (me being one), where the truck hit a bump, the tailgate bounced up and came off the hinges. This is not a good thing.
If one of the wires that keeps the tailgate from going all the way down when open, comes off, the tailgate will fly around like crazy on the remaining wire.
This can become pretty interesting at freeway speeds!
I've also been advised by a Calif Hwy Patrolman that a tailgate in the down position, with nothing to keep it from bouncing up could be considered an unsafe load.
It also bears mentioning that the tailgate also serves as support for the bed, if you ride around too long with the tailgate down or removed, the sides of the bed will loosen and eventually start flappin in the breeze.
Here is a little info on tailgate down.
  • 2 months later...
Keep the tailgate up. There are many reasons to keep it up and only one unproven reason to keep it down. Think of it this way. The auto makers have to keep the mpg as high as possible for the entire line of vehivle or else pay high penalties. If they thought they could get better gas mileage with the gate down, they would make a gate that allowed the wind to pass through. Having the gate down can ruin the gate, makes lots of noise, someone can drive into it at a light, looks stupid, and hurts mpg. This is a no brainer. Please don't be a complete redneck and use one of the nylon strap style gates.
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
