Towing capacity
I got a 98 GMC ext cab 8' bed K1500. It has a 6600' GVW. I added a tranny cooler just cuz I wanted to. I haul a 4000' trailer. What can I really haul cuz I wanna move up. It has a 5.7L auto and a 3.73 with a 14 bolt rear with the camper package. Any clues where to go to find out would be appreciated.
Thanks!
SCOTT.........
Heres what my 97 GM trailering guide sez for ball hitch towing..................
1/2 ton ex cab 4x4 350 3:73s auto..........
max trailer weight 7000 lbs.
max. tongue weight 800 lbs.
Note: max. trailering weight is calc. assuming the driver and 1
passenger are in the tow vehicle and it has all the required
trailering equip. The weight of addl . pass. and cargo in the
tow vehicle musr be subtracted from the max. trailer weight.
Thanks for the info!
I do use a weight distribution hitch and I know the GVWR is a little heavier because of the 8' bed on the extended cab model(6600 lbs. vs. 6200 lbs.). I just didn't know the max towing.
Thanks again!
The GVW is 6200 lbs. No mention of 6 or 8 ft. bed mentioned.
The 6800 lb. GVW rating is for diesel engine..............
The GVWR is listed as 12,000 lbs.with the following note:
To attain the GCWR, KO4 engine oil cooler is required unless engine
RPO includes heavy duty cooling equipment.
    Selfman
    Selfman
  • Who's Online   5 Members, 0 Anonymous, 672 Guests (See full list)
