Need opinions on used Duramax's
Hi guys,
I am considering trading my Silverado, 2002 5.3l with 80,000 miles for a used Duramax. If I did, it would probably be over 100,000 miles and most likely a 2002, 03 or 04. What experiences have you all had with the Duramax? What year is the best? What problems should I expect or look out for. What are the strengths and weaknesses of each year? Is 100,000 to 150,000 miles too many if I can get a one owner truck? Please give me any input or opinions you have.
The Duramax is a great engine. The only widespread problems are injectors, but they are warrantied for 200,000 miles. Why do you want to get the diesel? Your looking at trading for a truck will almost double the miles. IMO, I'd stick with what you have unless you need the diesel. My concerns would be 1. most diesels are built to tow/haul and 150,000 towing miles is alot, and 2. the widespread use of chips. Chips don't hurt the engine, but people tend to drive the truck harder once they get 150 more hp. Basically it's up to you. The Duramax has very few problems, and is a good motor.
Thanks for the input. The reason I am considering it is because I need to start towing more than when I bought my truck 4 years ago. Particularly a fifth wheel trailer.
Ayone else have an opinion?
If you do this, go with a 2003 LB7 Duramax. It is a great engine - more so, I believe than the LLY which replaced the LB7 in 2004.5
Yeah, the LB7 will provide plenty of power and good gas mileage.  The LLY has more power but doesn't get near the mileage.
The LLY may be rated higher from the factory but you wouldn't know it driving the two back to back. Jump in a new LBZ and you will feel the difference. For me I could not tell any difference between the LB7 and LLY's I have driven.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
