Only Marines would appreciate this
clm7214
Thats right, I made it all out of STRIPPER CLIPS! A Cpl chevron, my name and an Eagle Globe and Anchor. I made two more EGA's after this one, had to give one to the 1stSgt and one to the MGySgt. Tell me what you think? As far as anyone knows, the EGA is the 1st one made.
Ack...I will NEVER miss the Copenhagen in plastic cans.
You got that right!! After 2 years i have 20 days left till i can get REAL Cope again.
Well, I quit a few years back after watching dad die slowly of tongue cancer...But I still remember how crappy the plastic canned stuff was. :cheers: I would switch to Skoal whenever I was overseas.
Yup, pretty much a GRIZZLY man now. Cant dip Skoal. Picked some up in the Phillipines once, when the ship had to refuel, and puked while having a dip out on the deck. Never gotten sea sick except when i dipped that Skoal. After that, my brain makes me sick when i see it. Sorry bout your dad.
Well, I quit a few years back after watching dad die slowly of tongue cancer...But I still remember how crappy the plastic canned stuff was. :gmc: I would switch to Skoal whenever I was overseas.
Uck, Forget that, I go with Timberwolf when I'm low on change. I think it's 1000 times better than Grizzly! I'm not a fan of the new Copenhagen Straight, I like the original (gold lid). Back when I was at Ft. Lennard Wood it was 3.90 a can..here at home its 5.02. None of that flavored crap for me, straight only. Flavored stuff burns my gums right up.
I remember my 1sgt back in basic, I swear it looked like he put in 1/2 a can at a time. Only black guy I've ever seen dip besides the co. commander. Guess it's a Ranger thing. I remember wishing I had some.. :mad: good times.
Guest chevydeerhunter
I was a Cope man for a long time. The only time I ever tried Skoal, I bummed a dip from a buddy and went on some amusement park rides. I threw up my boots I was so sick. I finally quit some 13 years ago and I saved up enough to put a good chunk of change on my truck. I'll have it paid off in a couple of months.
    • I have a 2026 base 1500 "WT" regular cab. How many speakers do I have If I want to upgrade? Is the audio amp separate from the radio/display unit? [I listen to classical and it gets a bit raspy at slightly higher volumes.  Don't need a sub etc.] Do I have two or 1 speakers in the doors? Thanks Bill  San Jose
    • probably won't get a response from that user, as they haven't returned to the site since making that one post.  users don't (at least I don't, and I haven't seen any setting which would notify me via say, email) get any notification other than going to this site, and checking if they got a response on their thread...
