Anyone install a Cold air kit? Any improvement?
Hey, just wondering if anyone has installed a cai kit on their trucks. I've been thinking about it for awhile, I want to get that AEM dry flow filter kit for my truck. I've got a Magnaflow exhaust system and had the cpu sent out for reprogramming. The truck seems to definetly have more power on the upper rpms, but I'd like some more low end grunt (i.e. be able to smoke the tires for once). I know i've lost some power due to the 285's, but I've seen two magazine reports now that say the AEM kit is good for like 15 horsepower on the dyno. They say its their most responsive kit. Just wondering what your results were.
CAI's won't make any/much low end power, look at where they make their claimed HP it is in the upper RPM range save your money.
Dont' think you'll get the results you're looking for.
But it does sound better :uhoh: ....my opinion of-course.
Most people buy them because of the advertized claim to extra power............but if you take a pole on people who have bit the bullet and installed them........most, probably 90%+ say all they do is make some extra noise under the hood...........save your cash..... :uhoh:
Matt, Some think I probably work for TrueFlow but I do not. I have a True Flow "real CAI" on my Yukon XL and it did make a diff, although it was nothing earth shattering. I would agree with Cameron's statement above. If it is pulling air from unde the hood, it is not a Cold Air Intake system.
I bought a TF set up because it does retain the factory box and pulls cold air from the fender well area. It is much quieter than an open element unit but it can still be heard under a load, it produces it's 14Hp and 17ft lbs of tq (approx, my memory is not good) in the mid rev range and they do all their testing with the hood closed on the truck, which is how I hope you drive. Some companies test with the hood open and cooling fans blowing air on the open element. They also use a oiled dual stage foam filter that filters better than cotton gauze but does not flow quite as well. The oil contains a glue agent to keep it from sucking into your Mass Air Flow sensor.
Check them out on their website.
Mine has been on my truck for about 9 months and I have had no issues. It looks great, is a quality piece and I can tell some difference when towing my camper. It seems to help from about 2200 RPMs up. I cannot swear it made the diff in my MPG but I picked up almost 1 MPG after the install. I had a good record of my previous 7 or 8 tanks and ran another avg after the next 5 or 6 tanks.
It is expensive so you really have to decide is the small gain worth the $s.
Do you have custom tune setup for that intake? just curious.
From what I have heard on the net, that product is the best out there right now.
I would love to get one some day, but right now the output of it, is not worth the cost of it to me. But that is with any CAI.
Oh also, I've mostly heard bad with the K&N products.
Cameron, no tune. The folks at Hypertech scared me away from using a canned tune such as theirs. They tune for an outherwise stock veh and the tech at HT told me that they did get their share of calls with codes set because of their tune being added along with a CAI. I would assume a good custom tuner would take the CAI into consideration when working his magic.
I may do this one day, but this is my Wife's daily driver. I did the intake becase I liked the way it cleaned up all that snorkle junk under my hood and I was looking for a little boost in grunt to help me when tugging my camper.
I bought the K&N air charger system for my truck. If I had it to do all over again, I don't think I would have spent the 220 bucks on the system. With that being said, I still have it on my truck. One of the reasons I like it is the engine sounds louder under the hood on acceleration, which is a plus for me as I shift based upon the engine, not any of the gadges. I don't think these systems really give you the boost in performance they claim. -Shoot2Thrill
:uhoh:
What I did was to order True Flows air filter online for about $40 and then I bought an Airaid intake tube for $100. So basically I have the same effect as True Flows "Cold Air Intake" but for $100 less. Granted the mandrel bent tube you get in the True Flow kit is nice, but not an extra $100 nice :smash:
Ed, I would have likely done the same thing if I had of thought of it.
How do you like the TF filter?
I like it quite a bit. What I did not want was a K&N filter or any type of gauze filter since I am convinced that they filter poorly based on tests results I've seen. What I like about the TF filter is that it flows about as well as a brand new paper element filter, but it maintains that same level of flow even as it gets dirty. One thing that the TF website points out that I had not thought of before is that with a gauze filter like the K&N, every time you clean it you lose some of the gauze material. So you start with a an air filter (gauze) that does not trap dirt that well to begin with and you gradually make it worse every time you clean it. The foam of the TF filter is about 2" thick and will not degrade over time when you service it. Like you I researched this quite a bit and I would not use any air filter on my truck except a paper filter like oem or the True Flow filter.
    • I tried tapping it.  This might sound like a dumb question, you should feel vibration or some type of noise when it turns on? Can someone please verify? Thank you all!
    • I feel better now for my own view point and actions or lack there of towards the dealership service theme reading your post and others. GM corporate is who offers the two free oil changes on the HD trucks and I bought my truck in Feb of 2025 and those oil change offers run out within 2 years I believe and I highly doubt I will be using either one of them. I had asked if I could officially give those free services to another customer ( a friend ) and they said no, its all a GM corporate thing based on the vehicle in question. What that service advisor did however was go into a little story about how such and such customer was denied engine warranty because he had done his own oil changes because then they are not documented ... you see where that goes and so an employee playing the game of scaring the customer into having the service work done there most certainly triggered my thought process. At a later date I did talk to the person who handles warranty claims at the dealership and she said to be sure to document the oil changes and keep receipts for the oil and filter ( coped the receipts from cases of Mobil oil and case of filters I bought from them ) and the vehicles VIN, the date of service, mileage etc and staple that together as a record I would give them if that was ever needed and I keep my own log book for services for each vehicle as well. Oh and about 8 months after I bought the truck the dealer starts calling me to offer a maintenance service since they haven't seen my vehicle show up on their system ... for the mere fee of 300.00 Canadian to change the oil and rotate the tires and a few other minor checks and I declined the offer, I get the call again a couple of months later for the same thing and she could tell I was not interested and she asked if they should take my name off the call list and I said yes, do that !.    By the way did you happen to keep your factory oil filter to open it up and see the surprises inside as I expect some will show up as per the odd little sliver of metal shaving and particles that the filter does trap along with bits of grey silicone sealer that come off of the inside edge of mating surfaces. I have cut open every filter so far on my truck although few miles but have changed the oil often and the second filter was vastly better with very little of anything, that first filter was the unsettling one as I expected it would be.
    • I get why they do this…but man…not ideal. I only extract on inboard boat engines because the drains are buried and even then I hate it because it’s easy to leave a quart behind with that method.   They should market it as an “oil refresh” not oil change!
    • I only get oil changed where I can watch. Valvoline pulls through the dipstick into a see thru glass. When done they show me the dipstick. About the only way they can mess up is using the wrong oil. But that secret wouldn’t stay secret long. Honda uses TQ wrenches on everything. You can watch through a plate glass window. Discount tires does that with tires. Trust but verify.
    • I would not argue that with you. It would be pointless to argue against the truth and you speak the truth.    My question and in fact the entire point of this thread is an exploration into the levers of wear which happens no matter how well we maintain our powertrains.    Some of these levers we exert a good deal of influence over which can and do result is lower wear, longer powertrain life. Some others we are sort of stuck with.    An engine is typically done when the ring to bore seal no longer is able to do the job effectively. Normally the first thing to go in a engine otherwise well maintained and adult driven is this seal.    Looking into the means, methods, products and attitudes that influence the rate of wear seems a worthwhile inquiry to me.
